going carb soon?
Old Feb 4, 2004 | 07:31 PM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
going carb soon?
okay i know i need distributor ,manifold(already on),cARB, now what do i do to the trann y about the lock up deal to save gas on 4th?
Old Feb 4, 2004 | 07:45 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
if only you opened your eyes you wouldn't even have had to post a question:
https://www.thirdgen.org/techbb2/sho...hreadid=222010
Old Feb 5, 2004 | 07:47 AM
Bandit5's Avatar
Personally, after switching to carb and losing lockup, I am going to go with this: http://shop.store.yahoo.com/whitespi...i70coloki.html
I trust them enough, so I am confident that it will work fine.
Old Feb 5, 2004 | 10:21 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
that post was no meaning
Old Feb 5, 2004 | 11:31 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
You should try searching I know someone had a link that show'd how to modify the wire connectors so it automatically locked up the TC once it shifted to 4th gear. I'm just gonna put in a throw switch I think, cause I don't want to take a chance with a kit (my trans doesn't downshift out of OD at all). That way I just throw a switch once I get out on the highway or on the interstate and boom I'm locked up until I click it off. I do most of my driving around town or in the country where there's a lot of turns so I don't really see OD that much of long periods of time.
Old Feb 5, 2004 | 12:38 PM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Two easy solutions.
One way is to go to a local Auto Tranny shop or Trans Parts wholesaler. They have Mechanical 4th gear lockup valve that replace the electronic switching. Several company's make them.
Other way is to Purchase a Transmision Torque Convertor Lockup kit. Several companies make a kit with everything that you need. Painless Wiring has just such a kit. Part #60109
700R4 TC Lockup kit
I believe that Summit carries a house brand kit as well. May be cheaper.
Edit: Oooops.... didn't see Bandit5's link...LOL
The Painless kit is an exact collection of all the parts that GM used on the Carbed LG4 motors to engage the Lockup TC. Excellant way to go.
Old Feb 6, 2004 | 10:19 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
DO U HAVE TO REMOVE THE TRANNY TO INSTALL THE KIT?
Old Feb 6, 2004 | 10:58 AM
Engine: 383 SBC
Nope just the pan. A transmission shop should have no problems doing it for you. All you're doing with the kits is replacing some swtiches on the valvebody and running some wires.
Old Feb 6, 2004 | 11:01 AM
Engine: 383 SBC
Here was the setup I was going to do for my car. https://www.thirdgen.org/newdesign/t...ueswitch.shtml
Like I said I don't normally see OD for long periods of time and I'm usually on and off the brake if I do which should unlock tq converter.
Old Feb 6, 2004 | 12:34 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
yeah but will that setup work without a ecm in the car?
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
