Choke won't open
Old Feb 14, 2004 | 02:50 AM
Frank_Blotto's Avatar
Car: 87 Camaro Z28
Engine: LG4, CCC
Choke won't open
My choke won't open, why could this be? It also idles high, at 2000 RPM, are these related? The choke light is on, so I'm going to check the alternator, but I'm wondering about the other stuff.
Old Feb 14, 2004 | 01:54 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
They are related, and it could be as simple as the blue choke power wire has come off the side of the carb. If you have a voltmeter, check for 12V on the wire when the key is in the 'ON' position.
Pete
Old Feb 17, 2004 | 01:54 PM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
The choke circuitry is totally different on 86-87(and some 85’s?) LG4/L69’s.
You are correct about the CHOKE light being triggered by a bad, or slow spinning Alt on 82-85 cars. if the wire to the carb is unplugged the CHOKE light will NOT come on.
Frank, your 87 has a choke relay. If it is not energizing, the CHOKE light lights-up. Could be a bad relay or choke fuse.
Old Mar 9, 2004 | 05:52 PM
BMF's Avatar
BMF
Car: 79 & 87 Camaro, 98 Z28
Engine: V6,305, and an LS1 pushin 440 at the tires, all motor
Transmission: everykind you can think of
I'm having the same problems. Where is this choke relay?
Old Mar 16, 2004 | 12:27 AM
83_1/2 L69's Avatar
Engine: 305 CC-carb
The choke fuse should be the on the top row of the right hand side of the fuse block. The Choke relay is mounted on the "Convenience Center". Should be next to the Horn relay above the turn signal flasher.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Fronzizzle
Sep 8, 2015 12:10 PM
luvofjah
Sep 3, 2015 07:08 PM
