Stock Elect Fuel pump
Car: 89 Formula
Engine: 5.7L 350
hey guys new to the board but my question is can i use my stock fuel pump from my 89 formula 305 tbi, i belive it pumps 14 psi and ill regulate it to 7 for the carb. with that said is it possible to use it, will i have to put a switch on it to turn it on and off?
thx for the input
thx for the input
Car: 1991 Super Sport
Engine: 388 ci
Transmission: TH-700R4, 3500 Stall
yes...
Yes you can use your stock pump (in tank for the TBI). I am doing it now, and I am running 520 HP at the fly in my 388 stroker, with a modified 750 Holley race carb. The only way/reasson you will have to add another in-line fuel pump is if you add a N20 system or a supercharger, some type of power adder. The stock pump will not provide enough fuel pressure with a n20 system being used at the same time, you will need another elct fuel pump to help if you go that route.
Hope this helps!
Hope this helps!
Transmission: 4L80E/4L80E
Use a regulator that includes a return port. If you don't, dead-heading the in-tank pump will burn it out.
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
