Choke Wont Open
Old Mar 3, 2004 | 09:35 AM
quadracerc's Avatar
Choke Wont Open
i JUST GOT MY 4BBL QUDRAJET CARB REBUILT ON MY 85 CAMARO Z28. WHEN I START IT IT IDLES AT ABOUT 2000 RPMS. I THINK THIS IS NORMAL FOR A COLD START BUT WHEN THE CAR WARMS UP THE CHOKE STAYS ON. IT IS A ELECTRIC CHOKE AND I DO HAVE CURRENT FROM THE WIRE TO THE CHOKE. WHAT COULD IT BE?
Old Mar 3, 2004 | 12:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard.
If you have voltage at the choke thermostat, then either the thermostat is defective, or the linkage is not operating correctly for some reason (adjustment, damaged, dirty, etc.).
(Just for reference, we tend to prefer lower-case typing - all upper-case is "shouting".)
Old Mar 4, 2004 | 08:00 AM
quadracerc's Avatar
Where can i get a thermostat? isn't that right inside where the wire connects to the choke?
Old Mar 4, 2004 | 10:01 AM
five7kid's Avatar
Most any parts store should have one or be able to get one.
The black plastic housing to which the wire connects is the thermostat. 3 screws (or pop rivets, if never removed), remove housing, install new.
Old Mar 4, 2004 | 11:35 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Or, when it was rebuilt, they put a gasket under the thermostat.... which will insulate the ground return from the heater from touching the aluminum bowl, which prevents current from flowing, which prevents it from ever pulling off.
Falcon50
Aug 22, 2020 03:26 PM
Pac J
May 17, 2020 10:44 AM
FueledSoul
Sep 29, 2015 08:58 PM
drumstixer
Sep 29, 2015 03:02 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
