Bad Mechancial Pump?
Old Mar 5, 2004 | 09:55 AM
Jim L. Saylor's Avatar
Car: 1983 z/28 t-top
Engine: 305 Carb LG4
Transmission: 5 speed
Quick question...
Do the mechanical fuel pumps fail SLOWLY, or do they stop working...I mean is it possible to have a fuel pump that should normaly pump 5-7 psi, only do 2-3? Or will it just stop working?
Jim
Old Mar 5, 2004 | 10:23 AM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
It's entirely possible. One way to tell is if there's gas in the oil. Then the diaphram has cratered and it's pumping gas into the oil. Check that first! It could still be pumping low pressure and NOT pumping gas into the oil, though.
Old Mar 5, 2004 | 10:28 AM
No gas in the oil...I had that on my 442 last winter though...really messed up my bottom end before I relized it...
Sounds like tomie to pull the old sprirter...
Thanks again!
Jim
Old Mar 5, 2004 | 10:04 PM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
YES, I had a bad "pump" that was not putting out enough pressure at idle.
The stock fuel pumps have a built-in pressure regulator (it's on the bottom of the pump), that's why there are TWO gas lines coming "from" the tank. The smaller line is a return.
When the regulator spring gets weak, it "returns" too much fuel, causing the supply pressure to drop.
My carb was acting like it had a weak Accel Pump. Replacing the pump/regulator fixed the "carb" problem.
Best $40 I've ever spent on the car.
Glowsock
Jul 24, 2025 03:15 PM
mustangman65_79
Apr 14, 2017 05:37 PM
xxx3man`
Sep 23, 2015 10:37 PM
backtothe80s
Sep 5, 2015 12:39 AM
Winchester1094
Aug 18, 2015 10:23 AM
