what fuel pump would you recommend for my built 383?
Hey guys, hows it going..
I have a 383 stroker (full solid roller, about 600 lift and 239 duration) in my 92 firebird. The carb is a holley 800 dp
The car was originally tbi, and i have yet to replace the fuel pump which recently died. What pump would you recommend? I have a holley blue but i only wanna do the swap once.. Should i use this one or buy something else?
Im going to take it to a shop because i dont feel like screwing with it. Guessing the stock fuel lines are fine?
thanks,
Shane
thanks,
Shane
Don't try to draw fuel through a dead stock in-tank pump. It's restrictive. Either get a high-flow in-tank or take out the in-tank pump and go to a straight-through carb-style pickup.
Putting that aside, a Holley Blue along with a good fuel pressure regulator will keep up with that combo. Since your car has a stock return line already you should consider using it- with a return-style fuel pressure regulator (3 port) instead of a dead-head style regulator (2 port). Return-style FP regulator setups are easier on the fuel pump and hold more constant pressure without "pressure creep."
i am going to definitely get rid of the stock pump...
how much HP will the blue support? i want something good to at least 500 hp so i dont have to do this again.
i just wonder if buying a in take replacement would be better since i have to pull it out anyway.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Im going to be using a Holley Mechanical pump to power my 383. Part number HLY-12-327-13 at summit. i am pairing that with the MAA-4309 3-port return style.
i just prefer not having to drop the tank or anything if i ever need to replace the pump. I like having it tucked right up there in the engine bay.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i'm using a holley blue on my camaro right now with a mallory 3 port regulator. i have ran new 1/2 inch send and 3/8inch return lines along with having my gas tank sumped. if you don't want the holley blue you could also use a carter, or the aeromotive pumps are really nice but pricey at about $250+
well i already have the holley blue...
Do i need to rerun all the fule lines, or can the stock ones support ~ 500hp?
as far as electric vs mechanical.. i dont really care.. i just want whatever is gonna workout best for my application
i have to drop the tank regardless to pull the old one out
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Your stock lines should fit the bill..as long as no power adders are in the future without a dedicated fuel system for it.But to feed the motor NA..they are fine.
Transmission: 4L80E/4L80E
Originally posted by ShaneBuss
im really suprised at the lack of posts/replies .. this board has really slowed down in the last few years... what is happening to all the thirdgenners!
Car: 1984 Z28
Originally posted by five7kid
They all hang at the Auto Detailing and Appearance forum...
lol.....one of the first funny comments i've heard from you in a while.
looks like im going to tow the car to the mechanic shop about a 1/4 mile from my house.... im gonna have them pull the stock fuel pump out and install the holley blue pump..
from there i should be in good shape!
thanks guys
(i dont have anyone to help me pull the pump, or i would attempt it myself).
thanks guys
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I would never use a mechanical pump with any sort of high performance motor - no reason to starve the motor of fuel.
I would suggest a good electric pump near the fuel tank - sumping is optional and not necessary at 500hp, unless you want to use nitrous or supercharge it later.
Maybe try a magna flow pump. I think they have actually changed their name to magna fuel but whatever. Their expensive but well worth the investment. They will save you fuel starvation thats for sure.
Car: 75 & 82 Z-28
Transmission: Saginaw 4 speed
For the street up to a certain limit mechanical pumps are fine, you will not be starving the motor of fuel.
To be safe though, an intank electric with a regulator is some safe insurance, but Ill doubt you need it with that NA 383.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Holley Blues power many pipe racks out there running isngle digits, we've got 3 blues and one black in our close group of racers, all work fine running mid 10's to mid 11's. I would personally stay away from BG pumps, heard lots of horror stories about these going south within a year and guys having to pay dang near full price to have them factory fixed. I'm going with the A2000 Aeromotive pump, wanna be different and a few guys running it seem to like to. Magna Flow is another great brand of fuel pump, but spendy. You can look at it as sure I'm paying a little more now for less headache later, or else skimp now and end up paying twice out of pocket and the hassle of redoing AGAIN!! I see too many people saving a buck today and spending it twice later, even some of my buddies that should be old enough to know better from experience-don't. Sumping is just a way to know the fuel is always going to be available when the hammer gets dropped.
