Edelbrock 650 Tuning
Old Apr 5, 2004 | 07:42 AM
bigj85z-28's Avatar
Car: 79 z-28
Engine: Built 406 w/ Nitrous Works 250 shot
Transmission: TCI Th-350
Axle/Gears: 8.5" 10bolt 3.73 and Auburn Pro
I have a 311 with a victor jr intake, an original lt-1(70's) cam, the cam specs are 317/346 duration and .458/.484 lift, and centerbolt heads off a caprice cop car. My carb is an edelbrock 650, had electric choke, and its been takin off. I know the parts dont match, and all my power is above 3500. The carb is too rich down low, up until 3000 rpms, and too lean up top, around 5200 rpms, and i get alot of lean pop up top.
How should I go about leaning it out down low, and making it a lil more rich up top? Also, what is the part number for an edelbrock 650? I havent found too much info on them. I have a tuning kit for it, with a few jets, springs and metering rods. Thanks for any help.
-Justin
Old Apr 5, 2004 | 04:46 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Either look at your manual or go to the Edelbrock website, they have it online. You want your cruise/power modes leaned out with smaller jets and your secondaries fattened up with bigger than stock jets. A lot has to do with your elevation too. PM me And I can help you get it tuned better in more detail.
Old Apr 6, 2004 | 01:13 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Changing the metering rod step up springs will leanout the idle a bit. use a lighter spring ( lower vacuum rating)
The top end popping sounds more like over advanced timing or lack of fuel delivery at high rpm.
Most stock distributors have to much mechanical advance built in. Shortening the advance travel will allow more initial timing (14-18+ degrees at idle) for the big LT-1/Z-28 solid cam while maintaining proper total timing (32-36degrees at hi rpm)
Test the fuel pressure while running at WOT high rpm.
Anything below 3 PSi is susupect.
Could be weak valve springs too.
Bubbajones_ya
Jul 6, 2024 08:32 PM
bbsr72
Apr 2, 2016 09:12 AM
sreZ28
Oct 22, 2015 08:21 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
toronto formula
Sep 10, 2015 07:31 AM
