vortec heads with a nonvortec manifold?
Subscribe
Apr 7, 2004 | 06:52 PM
does any one know if its possible to do this? I heard that you just need to ovalize the boltholes on the manifold and it will bolt up is this true.
thanks
walter
Reply 0
Apr 7, 2004 | 07:29 PM
No you cannot just ovalize the bolt holes on vortecs. Whoever said that is thinking about adapting a post-1987 heads with a pre-87 manifold (the 4 middle intake bolts are slightly different - vortecs dont even have center intake bolts). You *can* drill and tap vortecs for standard bolt pattern but it completely defeats the purpose. The ports will never line up and you'll waste a ton of power.
Reply 0
Apr 7, 2004 | 07:37 PM
thank you for that info i appretiat it
Reply 0
Apr 7, 2004 | 10:52 PM
Paceparts.com sells vortec heads modded for 86-prior intake manifolds. You have to run a thick *** gasket though. Defeats the purpose. The vortec style intakes aren't to expensive anymore. I'd just get that. Because if youve ever seen one its WAY different.
Reply 0
Subscribe
