Vapor canister question
Old Apr 20, 2004 | 09:29 AM
70BuickSleeper's Avatar
Car: 84 Z28
Engine: 305 HO
When I bought my car, almost all emissions were removed. Its an 84 z28, edelbrock intake, demon carb, mallory hei. The vapor canister is like halfway connected.... The hard line comes up and connects to what i think is the pressure control valve, and then to the canister. that valve has a little vacuum port on it that is not hooked up, what should that go to? full manifold vacuum? ported vacuum? So it goes from the hard ventline to rubber to that valve then to rubber then to the canister. However, the second line off the canister is just cut and hanging there, its a big vacuum/fuel line, like 3/8s maybe. Where should that be connected to? The car seems to drive good, I dont ever really smell anything unless i park it in my garage for awhile, then its just a weird smell. Is the way it is setup ok? I would like to have it working correctly. I hope I explained this situation good enough.
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
TheExaminer
Aug 26, 2015 04:59 PM
redmaroz
Aug 16, 2015 11:40 PM
