carb to tpi
Transmission: 4L80E/4L80E
Any compelling reason to do this change?
I have nothing against TPI, if that's what you've got. Typically, though, it makes more sense to run what you've got and make improvements to it. Going from an LG4 induction to TPI won't improve power, and will produce less power than an LB9. If you want your car to run better, concentrate in other areas: air cleaner, exhaust, cam, head porting. In that order. You might want to add ignition upgrades while you're at it.
beachrodder
Aug 25, 2015 08:05 AM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
