jets in cc q-jet
Old Apr 27, 2004 | 09:00 AM
Cole's Avatar
jets in cc q-jet
I'm assuming that the jets in a cc q-jet are removable, but is there a tool made to do this? They don't have the normal slot for a flat head screwdriver. Should they be removed when I'm cleaning everything out for a rebuild? Also, is there any reason to remove the accelarator pump lever from the airhorn before dipping it since the linkage to the lever can be undone and the airhorn removed with the lever still attached? The fulcrum looks more like a rivet than a pin and doesn't want to be driven out.
Old Apr 27, 2004 | 12:11 PM
Nitsujx82xZ28's Avatar
Car: 1982 Camaro Z28
Engine: 305 ci V8
Transmission: auto
I dont think theres any reason to take them out unless you want to replace them, and the lever would be fine staying on.
Old Apr 28, 2004 | 01:09 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
If you are refering to the secondaries hangar/metering rods, then this is the deal. That is a star bolt, which a regular allen key will also fit. Change the hangars and metering rods, stick back in and tighten the bolt up. Easy.
Old Apr 28, 2004 | 02:43 PM
Cole's Avatar
I'm refering to the primary jets. Each has two flat spots on opposite sides of the jet which must be for a special socket or driver of some sort.
Old Apr 29, 2004 | 12:08 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Send a PM to five7kid... he's kinda the Qjet guru around these here parts.
Old Apr 29, 2004 | 07:58 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I usually just use a pair of large needlenose pliers or lineman's pliers to pop them out. Removing them does help to get all the schmutz out of the wells under them.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
69GTOby
Apr 18, 2016 02:34 PM
Marc Brown
Fabrication
17
Sep 25, 2015 03:43 PM
mackjar66
Sep 14, 2015 01:17 PM
