how to adjust air flow in carb ?
Car: Pontiac Trans Am
Engine: Stock 305
when i floor the gas in drive, from a stand still or while cruising at any given speed there is always a delay for about 3-4 seconds before the engine actually kicks in.
now i was told its probably to much air is getting to it first before the gas? now is this a common, fixable thing ... does this even sound right with my problem ?
is it a double pumper or a vaccuum secondary carb?
i would try switching to a lighter secondary spring, if it's for a vacuum secondaries carb. if not, could be that your accelerator pump is not doing its job.
Transmission: 4L80E/4L80E
I assume "stock 305" means q-jet.
Go here first https://www.thirdgen.org/newdesign/tech/quadrajet.shtml . The very first topic is what you're experiencing. Before you do anything, though, make sure your ignition is up to snuff. Retarded timing, weak plugs, wires or coil will also come into play here. And, most cars will tolerate an increase in base timing advance, up to 6 degrees is not uncommon.
The secondary tuning is all what q-jet performance is about, especially a computer-controlled q-jet.
Engine: Stock 305
Originally posted by onebad82z
We need more info!Engine?Intake?Carb?Cam?Converter?Trans Type?Rear Gear ratio?Be specific
1984 Pontiac Trans Am
305 ci V8 LG4
700-R4, which i assume is the stock one.
imma read that article thanks.
eightsixseven
Dec 16, 2024 01:50 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
