air gap and booster
Old May 8, 2004 | 09:23 PM
badazz84camaro's Avatar
air gap and booster
I have a Demon 650dp on a RPM air gap manifold and the problem i am having is what to do about the vacuum for the booster because the bowls on the carb hang over the vacuum port on the manifold. What should i do because i need to run vacuum for my booster and PCV but only have one big vacuum port on the carb. thanks.
Old May 9, 2004 | 07:41 AM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
You could use a T fitting to connect both to the port on the carb.
Old May 9, 2004 | 10:56 AM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Edelbrock makes a 90 deg low profile fitting to solve this exact problem. Part #8096
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
edoff13
Sep 11, 2015 03:55 AM
scotrans am
Sep 5, 2015 04:26 AM
