Electric Fuel Pump Wiring
Car: 1987 Camaro
Engine: 383
Transmission: Built Up 700-R4
I am getting ready to install a Holley "Red" electric pump. I am having fuel starvation issues with just the mechanical pump. My question is, can I wire the pump off of the wiring that goes to the tank? Can I hook the pump to the tan wire, or is that too much load for the wire? I would prefer to not have to wire up a switched relay to the battery.
Thanks.
Thanks.
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
I would run the Holley pump from the grey wire just as you suggested. That way you're already fused (20 A) and it is switched by the oil pressure switch off the engine.
If your ride is factory injected the ECM will prime the pump for a few seconds before cranking too. It's all good.
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
