Fuel Lines
Old May 18, 2004 | 10:59 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Fuel Lines
OK I did a search for fuel line and evap canister etc. I need to know which line on the pass side of my 87 T/A (LG-4) is the supply line and which is the return. One is larger than the other and I am assuming that it is the return but I am not sure. It has been 9 months or better since I pulled the 305 and I didn't mark them and forgot.
Old May 18, 2004 | 11:38 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The return is smaller than the supply.
Old May 18, 2004 | 10:36 PM
my3rdgen's Avatar
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Cool. I wasn't sure because the smaller of the two was the one dripping gas. For a month or so I would smell gas real bad in the garage, and there would be a small puddle under the smaller line that would come and go. It would get worse with weather changes. I eventually plugged it off after a couple of weeks or so to stop the leaking. The tank was about 1/2 full.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
