Do I need a bracket?
Old May 20, 2004 | 02:28 PM
Hollis's Avatar
Car: 82 Camaro Z28 Indy 500 Pace Car, 98 Firebird
Transmission: TH200
Im buying an edelbrock 600 cfm manual choke carb tomarrow and was wondering if it has a place to atatch the TV cable or will I need to go buy a bracket or something?
Thanks in advance
Old May 20, 2004 | 02:32 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
If your current bracket bolts to the intake you are fine.
As for that carb, why?
I have a edle 600, and don't like it. Go with a holley
Old May 20, 2004 | 02:59 PM
Hollis's Avatar
Transmission: TH200
thanks.
Im getting the edel carb brand new for $50, so i didnt want to pass that up. I have a Q-jet on it now that is completly shot and giving me between 2-3 mpg, I also have a Holley 1850 but it needs a rebuilt beacuse it was leaking gas every where and didnt have a bracket for the TV cable on it.
Old May 20, 2004 | 03:52 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
yeah, $50 is too hard to pass up, good find
Old May 20, 2004 | 10:12 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
the only thing you might need is the little stud that bolts to the linkage to hook it too and you might be able to take that off of the quadrajunk...
Old May 21, 2004 | 10:52 PM
Hollis's Avatar
Transmission: TH200
Well i got it on today and theres nothing to hook the TV cable to but also my accelerator cable wouldnt conect. Where can i get something to hook them both up?
Old May 21, 2004 | 11:56 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
Are you having problems hooking the cables up to the bracket?
Or
Having problems having problems hooking up the cables to the carburetor?
You should be able to pull the throttle linkage stud off of your old carb.
Old May 22, 2004 | 12:07 AM
Hollis's Avatar
Transmission: TH200
I tried taking the studs off my Q-jet and my holley nothing will fit, shouldnt the accelerator cable hook to the carb with out extra parts though?
Old May 22, 2004 | 12:12 AM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
well, a new edelbrock carb comes with the throttle stud. Drop buy your local checker, or kragen, one with a "performance" section.
With all the holley parts there should be a small box of throttle studs for like $5.
One of those is the right size. or, you could always go to the hardware store, get a small bolt and a nylon lock not, put the bolt loosly in the throttle linkage, put the throttle cable on, then put the lock nut on loosly. should work about the same.
Old May 22, 2004 | 12:26 AM
Hollis's Avatar
Transmission: TH200
It has a stub for the accelerator cable on it but the hole in the end of my cable is to small and doesnt fit over it. I dont have any of those stores around here, autozone and o'rilleys are the only ones and they dont have much.
Old May 22, 2004 | 12:28 AM
THEGENERAL's Avatar
heres what you need to make it work man check this out and this will give you an idea or you can just order it here http://store.summitracing.com/defaul...-20-2&x=22&y=6
Old May 22, 2004 | 12:40 AM
Hollis's Avatar
Transmission: TH200
Thanks, that exactly what I need
Old May 22, 2004 | 12:42 AM
THEGENERAL's Avatar
no problem ...sometimes they dont include those little pieces with the carbs and it leaves ya hanging wondering wtf do i do now.....lol..ive been there done that ..glad i could help ya
Old May 22, 2004 | 09:40 PM
ljnowell's Avatar
my accelerator cable wouldnt fit over the stud on my edelbrock, so i just took the ball on the stud over to the bench grinder and made it so that it would fit. took about 30 seconds. All you need is another stud to put in the bottom hole on the linkage for your kickdown and you are good to go.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
meeklay812
Oct 1, 2015 03:46 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
armybyrd
Sep 26, 2015 03:37 PM
