Starting woes...
Old May 21, 2004 | 12:27 AM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
Starting woes...
Ok here's my setup right now: Holley 600 w/e-choke, MSD vac ad distributor, no computer. Recently, I have had problems starting the car in the morning. The weird thing is, it seemed to start better in the cold weather. Is it possible that temperature change could effect the choke settings. I give the car 2 pumps of gas before starting it. The choke closes and everything. But when teh engine cranks over, the car dies right out. I give it 2 more pumps of gas and it starts up w/o a problem. What is causing this?
Old May 21, 2004 | 08:11 PM
3rdgengmachine's Avatar
Car: 87 iroc z
Engine: 358 tpi
Transmission: 700r4 with transpack
Axle/Gears: 3.42 with powertrax
sounds like your lean dude.the colder it is outside the more fuel it takes to run your f body.id check fuel filter fuel pressure (should be at least 6 psi) and the pump itselfe.how does it run after it warms up and during normal driving.i bet the hotter the better.take a few plugs out and see what color the tips are.if they are white your lean black rich a nice shade of grey is what you want.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
