Hey new here. Which rods and hangers should I use for my Q-jet
Old May 30, 2004 | 09:50 AM
Chris`s85Z28's Avatar
Car: 1985 Z28
Engine: LG4 305 with a few modds
I have a 85 Z28 with a done up 305 and I want to know which rods and hangers would be best for my Q-jet?
305
272 H10 Crane cam w/ .454" lift and 272 dur.
305 heads with mild bowl job and 1.94 intakes
Edelbrock performer EGR intake
Headmann headers
Accel cap, rotor, coil, plugs, modul
Taylor 8mm spiral core wires
Shes been rebuilt carb to pan and fired up yesturday
Or should I put my 600cfm Holley on and play with that??
I thought you guys would like to see my car.
Attached Thumbnails Hey new here. Which rods and hangers should I use for my Q-jet-85-z28-burnout-1.jpg
Old May 30, 2004 | 02:00 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Somebody will probably recommend using DR secondary rods and something like a B secondary rod hanger.
BTW, welcome to the board!
Old May 30, 2004 | 03:41 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Start with the stock rods and hanger and work from there. Most of your power tuning will be on the secondary side. Try a AU rod and experiment with different hangers and air valve tension settings.
Because of your larger than stock cam ( built in EGR)
you may want to restrict the EGR flow into the intake somewhat.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Ghettobird52
Apr 21, 2020 08:44 PM
neilb
Oct 4, 2018 12:36 AM
Skwisgaar
Mid-West Region
Sep 1, 2015 08:41 AM
