who is running a Walbro 255 pump?
Old Jun 24, 2004 | 09:43 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
who is running a walbro255 pump with the stock fuel lines?
mostly i need to know for SURE if the stock return line is adaquate to keep the pressure at carb levels.
i want to run this pump since my carb setup is only temp, and i may run nitrous thru it later, and im eventually going into forced induction EFI...
i only want to replace the pump once...
i know its posted on here that it SHOULD work... i want to hear from someone whos actually done it. ( or if you know someone, could you give me their username or email?)
Old Jun 25, 2004 | 12:52 AM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
Your plans sound similar to mine, which is why I chose this pump.
I'm running one. Unfortunately I haven't been able to really try it out much because I have other issues to tweak, but the return lines are definitely able to hold the pressure constant as low as 4 psi through a variety of RPM ranges. For some reason, the pressure seemed to be steadier when I bypassed the fuel pump, but I think that may have something to do with the fact that the oil pressure shutoff kept kicking on, but I'm not sure. I also had a batch of bad gas which probably caused some problems for me.
Oh, yeah, I'm running a Mallory 3-port regulator to a Holley 3310. I ended up using a F*rd EFI filter inline after the pump in the stock location. I had an inline pump there that didn't seem to work very well.
So to answer your question, yes. The stock return line seems to work just fine.
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
