Secondarys stay slightly open after WOT????
Old Jun 25, 2004 | 06:28 PM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
Transmission: 5 Speed
Axle/Gears: 3.70 Posi BW 9 Bolt
I have a holley avenger 670cfm and for some reason anytime a punch it to wot and let it go the secondarys stay cracked open and make the revs about 2000rpm. As long as i dont go wot they work fine. i replaced the vacuum secondary diaphram grease and checked all the linkage and been workin on it for 2 days straight took the carb of 3 times checked about everything changed the gasket checked all the vacuum hoses and get nothing. Im stumped i cant punch it or i have to turn the car off and start it again so i dont know what it is???????
Old Jun 25, 2004 | 07:41 PM
IROC4LIFE's Avatar
Car: 1986 IROC-Z
Engine: SBC
Transmission: Manual Th-350
Axle/Gears: 9" Moser 3.89's Spool.
BIG vaccum leak. Get a New carb gasket.
What spring are you using in the 4bbls?
Also make sure the quick change cover 0 ring is in place and not leaking.
Old Jun 25, 2004 | 09:40 PM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
Nope no vacuum leaks aready changed the gasket twice they wont close completely i personally think its something mechanical that might be getting binded up like the little lever that connects to the secondary diaphram rod. I was looking for idea but ive checked all around for vacuum leaks unless a small header leak will cause that. The spring that came with it is in there its a silver or aluminum color.
Old Jun 25, 2004 | 09:47 PM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
Also theres no o ring on the cover and its not the quick change secondary cover.
Old Jun 25, 2004 | 11:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There shouldn't be any grease on the secondary mechanism.
You've probably got something misaligned/bent.
I thought all SA's had the quick change housing.
Old Jun 26, 2004 | 12:10 AM
AM Racer's Avatar
Avenger without a quick change?
Get it new?
If you're running more than one gasket under the base, you can warp it when you tighten it down to the manifold.
Old Jun 27, 2004 | 09:35 AM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
Theres only one gasket i dont know if its the quick change housing you take off 4 screws if thats quick but i had to use a low tension spring to pull the secondarys completely shut so right now thats working right.
Old Jun 27, 2004 | 10:53 AM
AM Racer's Avatar
Was this a used carb?
It sounds like the wrong vacuum unit /diaphram.
I've gone through a problem like that a long time back. Not all the secondary diaphrams are the same. There are subtle differences in rod lengths
Old Jun 30, 2004 | 10:44 PM
AM Racer's Avatar
So what's the verdict doc?
Patient die on the table?
Old Jul 1, 2004 | 01:45 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
Did anyone replace the gasket between the main body and the base before, because the trick kits come with a few different sizes and it's easy to accidentally install a gasket with slightly smaller holes.
This causes the secondaries to bind up on the gasket and not close all the way.
Old Jul 1, 2004 | 02:27 PM
five7kid's Avatar
Holley Quick-Change housing.
If yours doesn't look like this, someone has messed with that SA.
Attached Thumbnails Secondarys stay slightly open after WOT????-hly-2059_m.jpg
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
luvofjah
Sep 3, 2015 07:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
