DYNO #'s in
Old Jul 5, 2004 | 03:08 PM
matt_82transam's Avatar
Car: 82 T/A
Transmission: th350 w/ high stall C.
DYNO #'s in
Hey im finally back.
my setup finally got dyno'd
-350 from 69 camaro bored 0.030 0ver
-rpm airgap intake manifold
-compcams xe262h cam
-edelbrock thunderseries 650
-holley red electric fuel pump
When I had it on the dyno, I tried an 8% richer rod, and three different acc. pump stages and nothing would solve the off the line fuel reqirement.
With all of these mods and the not enough initial fuel shot, I managed 330hp@ 5100rpm
and 350 ftrq@4800.
**I didnt rev past 5100 but it seemed like the cam was dropping off so i didnt want to rev further**
As soon as I can sell my 650 edelbrock and get the holley 650 double pumper I will have my initial fuel requirement met and hope for better performance with a possible 30-40hp increase.
The dyno numbers were reached with 2 pulls consisting of minor initial timing changes..plus 89 octane fuel and a small 10" air filter
Old Jul 7, 2004 | 02:35 PM
84zeddd's Avatar
I`m guessing you were using an engine dyno.You might see 350hp with a better carb.1hp per cubic inch is a respectable
goal.Did you advance your cam 4* or is it ground 4* advanced?
Old Jul 9, 2004 | 01:47 PM
Car: 82 T/A
the comp cams are ground 4* advance out of the factory but initially with my old setup (edelbrock EPS, old distributor) I installed it an extra 4* advance with the impression that low rpm power will be plentiful.. RESULT..100% WRONG.
THerefor because I had to change the crappy old tranny I thought why not take the trans. and and engine out, only a 2 days job so I did. In the process I changed the intake to an rpm air gap and I installed the cam at 0*.
THats how I got my decent dyno #'s , even with insufficient initial fuel shot(hurts 60ft badly) and using 89 octane, and small 10" filter.
thanks for the reply, I look forward for more
Old Jul 12, 2004 | 07:50 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Did you try a larger accel pump squirter nozzle?
http://www.cardomain.com/member_page...217306&page=26
Old Jul 13, 2004 | 10:37 AM
Car: 82 T/A
actually i didnt. I know that is what i need, but I haven't seen one in the edelbrock catalog but i will check again.If I find one Il try it out and save myself the purchase of another carb.
hey 305 sbc, are you putting out 440 hp to the wheels???
if so tell me your setup, maybe I could learn a few tricks from you.
Old Jul 14, 2004 | 07:39 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Yes Edelbrock makes bigger squirters. Look at the number stamped on the top of the squirter. I swapped mine to a #43 (see pic).
There's some info about my old engine on page 18 of my site. It's 440 rwhp.
http://www.cardomain.com/memberpage/217306/18
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
LT1Formula
Oct 8, 2015 08:34 PM
BBSDesigns
Sep 22, 2015 03:08 PM
