Need help with lean problem
Old Jul 6, 2004 | 05:55 PM
TN90RS's Avatar
Car: 90 RS
I recently installed a non-CC Qjet on my 90 RS. I'm experiencing a lean issue which causes pinging while driving anything above idle or under load. How do I adjust the Qjet to get rid of this problem?
Old Jul 7, 2004 | 12:28 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You can't.
The carb doesn't cause pinging, so no amount of adjusting it will ever fix it.
Your new vacuum/mechanical distributor that you put on at the same time as the carb needs re-calibration. You're getting too much timing advance at the wrong time for your engine.
Old Jul 7, 2004 | 12:36 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What distributor are you using?
Old Jul 7, 2004 | 06:25 PM
TN90RS's Avatar
Car: 90 RS
I'm using a pre-computer era HEI. The engine does ping less with the vacuum advance disconnect. I bought a advacne re-curve kit and was going to move the centrifugal advance to the mid-step. I also found the old centrifugal bushings were shot, which is probably causing some of it as well.
Old Jul 12, 2004 | 07:54 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
use the stronger springs.
yes worn-out bushings will give you more total timing.
Old Jul 12, 2004 | 07:55 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
yes worn-out bushings give you more total timing.
Old Jul 13, 2004 | 07:21 PM
TN90RS's Avatar
Car: 90 RS
Using the stronger springs. Engine still pings when under load, with the vacuum advance connected. Also, the engine has a serious bog at anything above light throttle until you get through the bog. Any ideas??
Old Jul 13, 2004 | 07:54 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Primary metering rods are stuck down in the pri jets.
Power piston stuck. Remove the top of the carb.
Old Jul 14, 2004 | 07:37 PM
TN90RS's Avatar
Car: 90 RS
Any good information on how to go about doing this?
Old Jul 14, 2004 | 07:44 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Use a screwdriver.
Yeah maybe the rods. Whatever it is is causing a lean condition.
Check your idle and part-throttle timing with a timing light to confirm what you're getting. Your vacuum advance may be stuck or malfunctioning as well and that would make it act lean and also cause the knocking. Advanced timing requires more fuel, so if your advance is too high then it will act too lean.
Too lean by itself would rarely just start causing spark knock by itself.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
