TBI to Carb.
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
TBI to Carb.
dunno if this belongs in here or the carb section. if mods feel it better in carb then by all means move it
we have the manifold and carb bolted on and think we have everything else figured out. just want to make sure on the fuel. we purchased a Holley 12-803 AFPR its a 3 port AFPR and i just wanted to make sure its what we need. here is a link to it.
http://www.jegs.com/cgi-bin/ncommerc...63&prmenbr=361
out of the three descriptions its the top one.
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
I cant really tell by the description if thats the one you need. Is it a return style regulator? If not youll burn up your fuel pump. Most of us TBI to Carb guys are using the mallory 4309 it works fine for me and its listed in the tbi to carb tech article. Good Luck.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The only 2 return style regulators out there, that I know of, are the Mallory 4309 and the one by Barry Grant.
OH btw this isnt going on my car. this is my friends 1991 Chevy 1500 with a 350. he picked up a Edelbrock Performer RPM intake manifold and Edelbrock 750cfm carb for $250. so it isnt going to work huh? i guess i understood the article that you run the pressure from the pump to the regulator and then the two out ports on the regulater one to the tank and the other to the carb. would that work? or do we need to get another regulator.
RedLeader289
May 28, 2019 01:47 PM
