TPS Problems
Old Jul 26, 2004 | 05:34 PM
bluroc's Avatar
Car: 1985 Iroc-z Camaro
Engine: L69 5.0 HO
Transmission: 5 Speed
TPS Problems
I'm certain the TPS on my ccc quadrajet is toast. If I unhook the wires going to it, the idle smooths out and it runs a lot better, no hesitation and great pick up. Does anyone know if it'll hurt anything leaving it unplugged? The mixture selonoid works fine, its just the TPS. By the way, its the factory carb on my 85 HO 305.
Old Jul 27, 2004 | 06:30 PM
eightTfourTA's Avatar
Car: 84 T/A
Engine: 305HOL69
Could be. I've had to replace my TPS every two years, on the exact month. If you've got a multimeter, backprobe the blue and black wires (blue being +, black -) on the TPS connector with the key in 'on' position and see what it reads. Should be about 0.48-0.54VDC at idle, and increase to around 4.5-5VDC as you open the throttle to full bore. If it reads funny it's probably bad. I wouldn't leave it unplugged for any longer than you need though, probably will run too rich.
92camaroJoe
Jul 29, 2023 07:57 PM
GTAman
Sep 21, 2015 09:57 AM
soarestransam
Aug 24, 2015 08:15 AM
92camaroJoe
Aug 13, 2015 06:07 AM
