Useing A Mechanical Pump w/ a TBI Pump
Old Jul 29, 2004 | 01:02 PM
JesasaurusRex's Avatar
Well my TBI pump is going/gone out since it only works for a while then shuts off. So I was wondering if I could disconnect the wire to the TBI pump and throw a mechanical fuel pump on there, just using the supply line from the old pump and going straight to my carb. Now I guess the question is will the mechanical pump pull fuel through the electric pump even tho the electric pump is not on/working. If yes should I get a higher PSI mechanical pump because the electric one will already act like a regulator or should I be good with getting a normal 6-8psi one. Thanks a lot guys, also its an zz4 cam so im not even 100 percent sure anymoer if its got a lobe for a mechanical pump.
Old Jul 30, 2004 | 06:46 AM
dmp7777777's Avatar
Car: 1982 z28
Transmission: th350
the electric pump only primes the system, you have to remove the electric pump and run the main fuel line to your mechainal pump
Old Jul 30, 2004 | 06:28 PM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
fuel pump
you wont be able to run the mechanical pump because the stok pump hasa check valve tht basically opens when the pumps on...so either remove the dead one and put a pikup for the mechanical pump in or jus getta decent in tank pump
Old Jul 30, 2004 | 08:08 PM
dmp7777777's Avatar
Car: 1982 z28
Transmission: th350
i took the electric pump out crimped the extra lines allowed for a vent and ran the line direct to the mechainical pump
Old Jul 30, 2004 | 10:39 PM
That sux thanx tho guys guess its time to get dirty. Appreciate it.
Old Jul 31, 2004 | 05:19 AM
dmp7777777's Avatar
Car: 1982 z28
Transmission: th350
i cut an "H" above the gas tank peeled the sides back to give me access to the lines and pump, not that difficult,some would say i butcherd it ,but the sides folded back down nicely and i sealed it,dont forget to leave a vent on one of the discontinued lines,but crimp it considerably so that its not wide open.estimated time ,3 hours
92camaroJoe
Jul 29, 2023 07:57 PM
gta90
Sep 15, 2015 04:00 PM
justin57
Aug 20, 2015 07:05 PM
formula_novice
Aug 18, 2015 08:48 PM
92camaroJoe
Aug 13, 2015 06:07 AM
