Any good plug readers here?
Car: '82 Z28
Just pulled out a couple to do a compression test and this is what I found. They've been in there since November when the engine went in. I'm guessing 6,000 miles or less since the car really isn't driven much but do drive hard once in a while
NGK plugs, guess they list them as aluminum vette head plugs. Thanks for any info!
Car: 84 Z28
Engine: 72 350 .030 over
Transmission: 89 WC T-5
That plug looks to be almost perfect. Has a nice tan color to the porcelin, slightly dark in some areas but nice overall.
Looks like it burns a little oil aswell, from judging the black around the perimeter. All in all I'd say its in very good tune.
Car: '82 Z28
About the oil, I'm not running a PCV valve at the moment
might try something tonight to get it hooked up.
might try something tonight to get it hooked up. Senior Member
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
might try something tonight to get it hooked up. PCV should eliminate most of that oiling on the plug. Looks good though otherwise.
evilstuie
Feb 28, 2016 03:33 PM
