edelbrock 1406 tuning.
Old Aug 13, 2004 | 06:39 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
this isnt on my camaro but you guys are about the most knowledgeable people on these things i can find so hopefully you will help me. this carb is on my 1978 Bronco with a 300 I-6. i think i have the jets in it fairly close, atleast the primaries. the jets are .095. and the rods are .070x.037. it will idle fine and if you open the throttle at a medium pace it does fine. but if you just crack the throttle open(stay out of the secondaries tho) it just dies and falls on its face. i tired the next step richer jet and it got worse and i tired a step leaner and it stayed the same but had no power. im running the pink spring right now. what im thinking is that im to rich on my power side of the rod. would that make sence? or am i too lean? im new to playing with this carb so any ideas are helpful.
Old Aug 13, 2004 | 08:35 PM
rjmcgee's Avatar
Is your Acc pump arm in the right hole?
Old Aug 13, 2004 | 10:43 PM
92MaroRS's Avatar
was in the middle hole. moved it to the closest to the carb. got a bit better but still not great.
Old Aug 14, 2004 | 12:05 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
When you say "crack the throttle open" what do you mean exactly?
Old Aug 14, 2004 | 12:09 AM
92MaroRS's Avatar
i mean like snaping the throttle open. just like with a flick of the wrist open then closed real quick like.
Old Aug 14, 2004 | 12:32 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
How is it if you floor it and leave it?
Old Aug 14, 2004 | 08:45 AM
92MaroRS's Avatar
after moving the link of the Acc. pump it stumbles and sputters and USUALLY takes off. before moving it it would always die. still does maybe about 25-50% of the time if i hold it open. i am keeping it out of the secondaries too.
Old Aug 15, 2004 | 01:12 PM
92MaroRS's Avatar
anyone with ideas?
Old Aug 15, 2004 | 04:22 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Is this a new carb or a used one?
Old Aug 15, 2004 | 04:25 PM
92MaroRS's Avatar
used. in good condition tho. was very well taken care of.
Old Aug 15, 2004 | 10:53 PM
mcgruff1's Avatar
Use the stiffest springs, I had the same problem you have and I never got it perfect..
Old Aug 16, 2004 | 06:23 AM
92MaroRS's Avatar
i already have the stiffest spring in there.
Pac J
May 17, 2020 10:44 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
