What carb to use?
Old Aug 25, 2004 | 08:23 PM
Wootah's Avatar
Car: 88 Iroc-Z
Engine: 355ci
Transmission: WC-T5
What carb to use?
My engine setup is down in my sig, and right now i believe im running a Holley 600 sec. vac., and im curious if this carb is going to be restricting power. Would a 750 be a better choice? Any input would help, im not much of a carb guy, so i dont really know which types of carbs are used in certain power apps. Thanks!
Old Aug 26, 2004 | 02:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
CFM required for max power = (CID x max RPM)/3456. That's the most the engine can use.
In reality, it will only use as much air as it is efficient. That factor could be as low as .85, with a really maxed out package it might approach 1.0.
Most likely it isn't hurting you. But, most people go faster with a bigger carb - up to the point where it bogs out on them.
Old Aug 26, 2004 | 03:13 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
That equation is also for steady flow. Actual airflow is in pulses due to the opening and closing of the valves. The effect is more prominent with dual-plane intakes.
Old Aug 26, 2004 | 03:29 PM
Wootah's Avatar
Car: 88 Iroc-Z
Engine: 355ci
Transmission: WC-T5
ok, at least i know this is fine for now.. maybe int he enar future ill throw on a 750 or something and see how it performs. Thanks guys i appreciate the help!
Old Aug 26, 2004 | 10:19 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
a 750 wouldn't be a bad choice.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
