missing at higher rpms
Old Sep 3, 2004 | 09:55 PM
jwilds469's Avatar
Car: 82 z28
Engine: 350 carbed
ok i took off my 759 dp and put on a new 650 dp the 750 was too big. it runs awesome but from first to 2nd runs fine from shifting from 2nd to 3rd and 4th at the higher rpm range it seems to sound like is missing. i personally think its the timing. i am goin to mess around with that then see if it still does it..........does anyone else have any more ideas what it is. thanks
Old Sep 3, 2004 | 10:01 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
is it running out of fuel pressure?
Old Sep 3, 2004 | 10:04 PM
jwilds469's Avatar
Car: 82 z28
Engine: 350 carbed
that could be a possibility cause i do have a mechanical fuel pump for now. gettin a electric pump is on my list of things to do
Old Sep 9, 2004 | 07:31 PM
tommyboy's Avatar
Car: 87 Formula
Engine: 355
Transmission: TH400
Axle/Gears: 5.00
Fast miss or a slow miss? If it is a slow miss, it could be a too rich fuel condition.
Old Sep 10, 2004 | 09:40 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
I had a simular problem, turned out to be timing too far advanced.
Old Sep 14, 2004 | 08:12 PM
jwilds469's Avatar
Car: 82 z28
Engine: 350 carbed
actually it was one of the wires on the dist. was showin some wire, making it miss, its all fixed now, runs perfect..........................................................................................................
update took to track friday nite was 2 seconds slower than normal times
on third run goin through the traps engine sounded a bit weird for a second, went to pits, idled normal, giving gas herd some wapping.......went home pulled valve covers saw nothing. pulled dip stick, seen slight metal shavings...thinking a bearing spun out.... welp time for a 383 woo aha ha haha
been racing for about 6 years, first time something major happened, can't complain that much
Old Sep 14, 2004 | 10:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The reported percentage varies from telling to telling, but approximately 75% of carb problems are solved by fixing the ignition.
In my experience, fixing reving problems has also been known to cause bearing problems...
eightsixseven
Dec 16, 2024 01:50 PM
xxx3man`
Sep 23, 2015 10:37 PM
Eric2ndGen
Aug 31, 2015 12:33 AM
someone972
Aug 30, 2015 12:52 AM
