quadrajet selection
Old Sep 9, 2004 | 05:09 PM
1984HO's Avatar
Car: 1984 Z28
Engine: LQ9 W/ Howards ASA cam+Fast 90
Transmission: T56 Mgw shifter
Axle/Gears: Currie 9inch w 4.30 gears
quadrajet selection
ok guys ive had it with my holly one of the fuel bowl bolts stripped so im gonna replace the carb i want a quadrajet non computer controlled, i would prefer one that was close and only required a little tuning. is that a realistic goal i have a mild cam in the engine 16 inches of vacuum in park warm idle at 900 (14 at 650 in gear ) would my best bet be to find one that came of a 350 ? partnumbers would be great or sites with info or if you have one sittin around let me know i am very intersted thanks
combo
305 HO
edelbrock performer
headman shorty headers
flowmaster exhaust
cam (dont know specs)
3.73 gears
700r4
:hail:
Old Sep 9, 2004 | 05:25 PM
65panhed's Avatar
Car: 1984 Z28
Engine: L69 305 HO
Transmission: 5 speed manual
Axle/Gears: Auburn pro yukon 3.73 gears and axl
Holley recommends that you do not tighten the bowl screws to tight. A stripped bolt hole does not just happen,don't blame holley, they did not send the carb out with a stripped hole.....
Old Sep 9, 2004 | 05:31 PM
1984HO's Avatar
Car: 1984 Z28
whooaaaa,
i wasn't bashing the holley. i realize that bolts dont just magicly strip, i was just saying that was the final straw. this carb appears to have been mistreated by its previos owners (big cuts where bowls and metering blocks were pryed off) i have rebuilt it once already and am just no a big fan of it. BUT I HAVE NOTHING AGAINST HOLLEY. the bolts were not overtightned while i owned the car in fact the bolt in question had already been helicoiled os it had been abused in the past. all i want is to know what others are using for non cc quadrajets thanks
Old Sep 9, 2004 | 05:46 PM
nsimmons's Avatar
Pretty much any qjet will work. Guys will jump in here saying only 60's style non emissions ones are worth messing with, not the case for an engine like yours. Im running a summit 1103 cam, have 15" at idle.
My carb is from an 81 pickup stickshift w/ ac.
It came on the car, but i was able to look up the number. We both have plenty of vacuum so the stock power piston spring is fine, secondaries can be tuned with the right hanger rod choice for your application, and idle mixture screws can easily be adjusted for your engine.
Really any qjet from before the 80's would work fine for idle and part throttle (after a rebuild), but you may have to hunt for different secondary rods to get maximum power.
Just hit the junk yards and try to find one with an electric choke, and no aneroid for simplicitys sake. The aneroid adjusts for elevation changes. Its located in the fuel bowl. Dead give away is a third primary jet.
These versions are more complex than needed.
I can get a complete qjet for 10-15 bucks here
Old Sep 12, 2004 | 02:28 AM
AnotherfastIROC's Avatar
Car: 06 Envoy, 84 Fiero, 86 Camaro
Engine: 4.2 I6, 2.5 I4, supercharged 355
Transmission: 4L60E, Muncie 4 spd, T-56
Axle/Gears: 3.42's, 4.10's, 3.73's
I have a Holley 575 street avenger left from a failed prject the carb is in perfect condition with exception of the gaskets on the front float adjustment, (casualty of a learning curve) otherwise the carb is perfect. drop me an e-mail if your interested. I Live in NJ. Thecat80@comcast.net
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
budowski
Carburetors
Oct 2, 2015 10:16 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
Mdenz3
Sep 17, 2015 08:36 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
