should I go with a roller block?
Old Sep 21, 2004 | 07:58 PM
lancerracer's Avatar
Car: 1988 T/A WS6
Engine: none right now
I am hopefully picking up a block this weekend for my carb buildup...I was wondering if I shouldget a block that has roller provisions? would it be beneficial for a carb build up for around 375hp at the flywheel? I am sorry if my quesiton is vague...but I am basically asking if i should pick up a roller block to use for my carb buildup Thanks
Old Sep 21, 2004 | 11:44 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Roller cams can make more power than a flat tappet in a streetable combo.
You might be better off asking in the GenTech/Engine Swap boards though.
Old Sep 22, 2004 | 07:58 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not all roller blocks have the mechanical fuel pump rod and oil return drilled. Something of which to be aware when you're out shopping.
Old Sep 23, 2004 | 02:52 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Get a roller block only if you want to go with a factory roller setup. If you can live with a flat tappet cam or want the retro-fit design (way better design, IMO), then get a flat tappet block.
That's my 2 pennies.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
anesthes
Sep 18, 2015 12:34 PM
RyanJB
Sep 14, 2015 03:39 PM
Nick McCardle
Sep 10, 2015 08:36 PM
