leaky carb
Old Sep 23, 2004 | 02:36 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
leaky carb
First off, my setup is an LG69 w/edelbrock performer intake, MSD Distributor set at 10*, 700r-4 w/ b&m shift kit, and a holley 600 w/ e-choke. I've been running the Holley for about six months now, and about two days ago I noticed that my carb was leaking fuel. It looks like it's leaking around the block-off plate on what would be the secondary fuel bowl fuel inlet(if that makes sense). My question is: how would be the best way to seal the leak? I was thinking about using some JB Weld and just perminantly sealing it off since i'll never need it. What do you guys think I should do? Any reply is appreciated.
Old Sep 25, 2004 | 11:04 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
sounds like the o-ring needs to be replaced or maybe its just out of place. I would carefully take it apart and check where that o-ring is at. If I'm wrong then I didnt understand you but it just sounds like you need a new o-ring or gasket somewhere, nothing to complicated.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
