lg4 to ho350 carb upgrade rear hanger and rods
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
i have upgraded my 305 lg4 motor to 350 cu in, edelbrock rpm heads,slp headers zz4 cam . In GM's H/O conversion the upgrade to the carb was to repl secondary metering rods. in the catalog it listed a part# for the new rods but it was a kit for like 90$. Has anybody done this conversion or know what i need to do this? See its not fast enough yet and richening this up should really help!
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I would suggest 2 things (and I did the same with excellent results):
First - pick up all the secondaty metering rods and hangars you can (for a good selection of parts)
Second - buy and install an a/f ratio meter (preferably a wide-band). It will allow you to monitor the a/f mixture in real-time. You want to run approx 13:1 a/f for max power (some cars might need to be richer).
Tune to get it right on the money...... then enjoy
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Re: lg4 to ho350 carb upgrade rear hanger and rods
All this does is quicken and richen the secondaries but what a rocket ride once it's set up!!!
Then go to the Tech Articles on this site and read over the QJet articles. They show you a couple of really simple things to do with the spring controlling the secondaries that allows it to open much easier so you have snappy 4 barrel performance RIGHT NOW
The QJet is an awesome street carb once you do these two simple things!
PS You might have to go to a high volume mechanical fuel pump now that you have a healthy 350 running the show. Make sure you get the high volume pump and NOT the high pressure one. QJets only like to see about 6 psi tops, so the high pressure pump is bigtime trouble. Carter and Holly make high volume units for about $50 or so.
Transmission: 4L80E/4L80E
You might consider the .149 needle/seat as well.
I agree with the B/DR combo recommendation. Amazingly versitile.
Car: 90 Formula 350
Re: Re: lg4 to ho350 carb upgrade rear hanger and rods
Originally posted by Sitting Bull
Here is the simplest thing to do. Go to a speed shop that will sell you QJet hangers and rods seperately. Most of them should do this for you and only charge around $10 for both. Get a B hanger and a set of DR rods. If you can't get the DR rods try for AY rods.
1992 Trans Am
May 10, 2023 07:19 PM
