did any 86-87 cars have electric fuel pumps
Old Nov 13, 2004 | 10:32 PM
redcamaro83's Avatar
Car: 86 Z28
Axle/Gears: TBD
this is why i ask.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7933438736
and autozone lists an electric for cars with vin H
Old Nov 13, 2004 | 10:58 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Yep. Reputedly, it was the factory's 'cure' for vapour lock.
A small in-tank electric pump fed the block-mounted mechanical one.
Old Nov 14, 2004 | 08:59 AM
Damon's Avatar
As I understand it all the L-69 305 HO cars had them regardless of year. The LG-4 305 low output cars did not up until about 1986 when they got them, too.
Old Nov 14, 2004 | 11:32 AM
Car: 86 Z28
Axle/Gears: TBD
oh ok cool. thanx next question is does anyone may a non competetion pupme that i can use with a standard carb pickup
something reliable its going on my daily driver and the new motor has no provision for a uel pump
do you guys think a tbi intenal pump setup with return style regulator would be ok?
Old Nov 14, 2004 | 02:44 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Yes, that will work well. If it is a QJet set your pressure to about 6 psi and you are laughing
Old Nov 15, 2004 | 08:28 AM
Damon's Avatar
I wouldn't bother taking the tank down to put a pump in it- that's a tough job. I'd just get an inline pump and mount it somewhere near the tank. Regardless, you're going to need a bypass-style regulator to bring the pressure of the electric pump down to carb-friendly levels. Mallory makes such a regulator and it seems to be the one most people gravitate to in situations like this. I use it on my 92 RS that is converted over to carb and it works great.
Old Nov 22, 2004 | 07:35 PM
69-er's Avatar
FYI...
The pump in the tank for L69's was a service bulletin for the vapor lock problem. They were only installed if the customer (me) complained about the rough running engine.
They finally put out another kit that supposedly works. I think it modifies the fuel entry into the jets at higher location so the fuel is a little cooler and not percolating. I have yet to install it. Over the years, the stumbling has somewhat decreased where it doesn't bother me near as much as it did when it was new.
Old Nov 22, 2004 | 11:54 PM
nsimmons's Avatar
l69 here, no intake pump
Old Nov 26, 2004 | 10:27 PM
ThommyDee's86Z's Avatar
Car: 86 Z28 w/ T Tops
Engine: 305 SB w/ Performer intake 3701
Transmission: 700 R4
Axle/Gears: stock
just pulled my tank today...No intank pump.
I've got an 86 Z28 Carbed 305. Block mounted Mechanical pump. I believe 87 is when the LG4 cars started with intank (or late 86 models)
Old Nov 28, 2004 | 10:56 PM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
So on these mechanical fuel pump cars, are the fuel lines run on the passenger side? Or are they still on the drivers side & then crossed over to the fuel pump? I'm not familiar with the earlier models & was just curious. Thanks
Old Nov 29, 2004 | 10:50 AM
Damon's Avatar
Yeah, the carb cars had both the feed and return lines run down the pass. side of the car. They pop out of the fram rail near the block mounted pump (down low). 3/8" feed, 5/16" return line.
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
