SES questions
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
SES questions
I recently rebuilt and installed a CC Q-jet on an 85 LG4. The first question I have is could a carb that was working improperly have somehow damaged the Oxygen sensor? The computer shows a code 13. I know the sensor is old and probably needs replaced, but I am trying to figure out what killed it. I know the car was flooding before and I suspect this is what did the damage. Is this possible? These sensors are relatively cheap so I will replace it anyway. The other question is, what causes a code 41? The car runs, so I don't think it is the module. I know the previous owner messed with the timing trying to fix the cars flooding problem. Could the timing being out cause this? I plan to check the timing as soon as I get my light back from a friend. I appreciate all responses in advance.
Car: 1990 Formula
Engine: 95 LT1
I replaced the pick up coil and reset the ecm and the codes all went away. What gives? Why would this cause all these codes. I used a GM manual to diagnose code 41 and it lead to the pickup coil. What would this have to do with the O2.
Transmission: 4L80E/4L80E
When you disconnect the distributor ECM connector and run the engine (as in setting the timing), the ECM sets a code 41.
Running overly rich can ruin the O2 sensor.
Car: 1990 Formula
Engine: 95 LT1
The other reason I replaced the pickup coil was because of what I found under the cap. One of the screws that hold down the rotor was out and stuck in the pickup coil.
eightsixseven
Dec 16, 2024 01:50 PM
