Venturi sleeves
Old Nov 27, 2004 | 05:13 AM
contactpatch's Avatar
Engine: sbc 350
Venturi sleeves
The issue of Venturi Sleeves is rarely discussed.
Why?
If they do what I think they do,
VSs [or other types of restictions]
would appear to be a fix a basic misapplication
of 4-barrel carbs...oversized primaries ...
causes driveability issues
[affects 99 percent of non q-jet carbs]
Old Nov 27, 2004 | 10:27 AM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TH-350
The only carbs with replaceable venturi sleeves are some expensive Demons (or its predecessor the Claw carbs) or Weber type carbs. Then there is the Predator carbs that have a variable venturi. To my knowledge the cost to try and add replaceable sleeves to any other carb would be so much you'd save a small fortune to just buy the correct sized carb.
GTAman
Jul 3, 2024 07:29 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
