how do you cure vapor lock
Old Nov 30, 2004 | 10:31 AM
redcamaro83's Avatar
Car: 86 Z28
Axle/Gears: TBD
car starts fine colds but after driving long periods or just enough to get hot, if i cut it off leave for 20-30min or so have to hold accelerator to floor and crank a long time before fuel comes and engine starts. usually runs rough for a min afew wot puches and it runs like a sewing machine.
Old Nov 30, 2004 | 10:48 AM
Zokal's Avatar
Car: 1989 Firebird Formula
Engine: Chevy TPI 350
Transmission: A/T 700 R4
You could always do it like the old school mechanics by putting something on the gas line to pinch it. I used to always use a clothes pin.
Old Nov 30, 2004 | 10:59 AM
Car: 86 Z28
Axle/Gears: TBD
did a search
will try some heat shield or rubber hose around the steel line next to block.
any other suggestions
Old Nov 30, 2004 | 11:03 AM
bulletboy29's Avatar
Car: '87 Camaro SC
Engine: 305 LG4
Cheapo electric pump back by the tank.
Old Nov 30, 2004 | 11:05 AM
Car: 86 Z28
Axle/Gears: TBD
like those cheapy facet pumps the local parts store sell for like 50
Old Nov 30, 2004 | 11:08 AM
Car: '87 Camaro SC
Engine: 305 LG4
yeah...I got one for $30. Think it's a purolator? sp?
Old Nov 30, 2004 | 12:04 PM
demonchild's Avatar
1) relocate the fuel line so it does not fun between the water pump and the engine block.
2) run a fuel cooler.
these will definently help out. However, if you have a stock 305, i dont see how it could be vapor locking unless there was another problem with the carb. You said you only have this problem after the car has been run for a bit and then shut off for 20-30 mins. This problem sounds more like too much fuel becaseu of the choke sticking open when its not supposed to. Take the chock apart, make sure the wound spring is in good shape and spray everything with some carb cleaner.
Old Nov 30, 2004 | 12:47 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
no one pointed out the real problem.
find out where, and teh reason why the engine/exhaust is dumping excessive heat into the fuel system.
then you solve that.
common problem is putting headers on, and not bending the fuel lines out of the way.
Old Nov 30, 2004 | 01:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That isn't "vapor lock"; it's the exact opposite of "vapor lock".
"Vapor lock" is when the fuel in the line vaporizes, and the fuel pump delivers fuel vapor to the carb instead of liquid fuel. Needless to say the car runs very very lean under those conditions, if it runs at all.
The condition you have is where the fuel in the fuel lines is very hot, yet remains liquid under pressure, and evaporates when in the carb; and bubbles all up out of the top of the carb and sloshes into the engine. Then when you try to start it, the engine is flooded, and you have to do the un-flood thing (hold the gas to the floor until it starts) and wait for it to quit blowing out black smoke before you can drive it.
The most usual cause is the fuel pump being heated up by the block. Make sure you have a fuel pump gasket, or even 2 of them; and a gasket between the FP blockoff plate and the block.
Old Nov 30, 2004 | 01:04 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
I would also check to see if you are getting a good spark. Ignition control modules have a tendency to fail when hot.
Old Nov 30, 2004 | 04:01 PM
Car: 86 Z28
Axle/Gears: TBD
yep will do u just keep helpin till it hurts...lol
thanx again
jrdturbo
Mar 31, 2016 02:58 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
kkirch15
Sep 30, 2015 04:44 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
