Idle help
Old Nov 30, 2004 | 02:53 PM
84BlueZ28's Avatar
Car: 84 Z28
Engine: LG4
Idle help
I have a q-jet and it idles way too high. when i start the car it kicks on high idle fine. once the engine is warm it doesnt kickoff completely. it idles between 1200 and 1500 rpm. i dont know whether its the choke or idle or what. any help would be appreciated.
Old Nov 30, 2004 | 04:32 PM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
My carb does this from time to time.
When I spray the linkages on the outside of the carb with WD-40, it works fine for about a year. Now I just re-spray it during every oil change.
NOTE: WD-40 is NOT a lubricant; it is a solvent (cleaner) and corrosion inhibiter.
You need to look at the choke to see if it is opening all the way. Warm up the engine then shut it off. Remove the air cleaner lid and look at the choke plate, it is mounted above the smaller pair of "barrels". It pivots on its center line. If it is open all the way (choke off), it will be vertical.
Old Dec 3, 2004 | 09:30 PM
fake formula's Avatar
Car: 1986 z28 camaro
Engine: 305 4bbl
Transmission: t-5
you may want to try a stiffer throttle return spring, or lubricate your choke/linkages as mentioned above
Old Dec 5, 2004 | 03:05 PM
83_1/2 L69's Avatar
Engine: 305 CC-carb
A good pair of eyeballs can see if there are any problems with the throttle or choke (is the throttle restting against the idle adjustment screw? Is the choke open all the way?). If all looks OK, you might have a vacuum leak.
Old Dec 7, 2004 | 08:27 PM
84BlueZ28's Avatar
Car: 84 Z28
Engine: LG4
thanks for the help on the carb. it just needed to be adjusted and lubed.
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
