stumbling
Old Dec 16, 2004 | 10:02 PM
84 t/a 5.0's Avatar
Car: 1984 Trans Am H.O.
Transmission: 700-R4
Axle/Gears: stock 3.73
stumbling
Hey everyone, i'll try to explain this the best I can. When I make a slow turn (not sharp) onto another street, and I am still giving it a little gas, it seems to cut off or something, as it won't accelerate and kind of stumbles for a short amount of time until i'm done with the turn. I'm thinking it has something to do with the carb. Any ideas? Oh yeah, it's a stock CC Q-jet in my 84 T/A automatic tranny.
Old Dec 17, 2004 | 12:10 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Fuel is sloshing away from the main jet. Check the float level.
Old Dec 17, 2004 | 12:10 PM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
How old is your fuel pump/pressure regurator?
If the regulator built into the bottom of the fuel pump is weak, the carb will not have enough fuel (low fuel pressure).
Test the pressure first, if it is OK then adj the float level.
Old Dec 17, 2004 | 12:22 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I'm with five7 on this one. Sounds more like a float issue. If it were pump related, it would be more of an "anytime I get on the gas" issue.
Old Dec 17, 2004 | 01:21 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Five7 probably has it but while you're there you may want to replace the float. They can soak and loose buoyancy over time causing problems and are cheap to replace anyway.
Old Dec 17, 2004 | 03:14 PM
84 t/a 5.0's Avatar
The fuel pump is fairly new, so i doubt that's it. I'll look into the float. Thanks alot guys.
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Logan Bryant
Sep 23, 2015 06:51 AM
RedLeader289
Sep 23, 2015 06:50 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
