Intake Manifold Gaskets
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Hey guys I am going to be getting the 7104 Edelbrock RPM manifold pretty soon.
What is the difference between Felpro Intake Manifold Gaskets and Felpro Performance Intake Manifold Gasket Sets?
Car: 1989 C4
Axle/Gears: 307
One is blue paper coated one is black embossed. Call a few parts stores and ask them for Engine Seal brand gaskets, they have a rubber coating that seal better then any expensive gasket Ive ever used.
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
i have never liked those china wall gaskets that go on the front and back of the intake. i like to make a pyramid 2 layers then one on top. it makes a good seal and wont blow out as easily as the china walls.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I've used the Fel-Pro 1204 and cheapy Mr. Gasket intake gaskets that have the silicone around the intake ports with great results. Throw away those junk rubber front/rear gaskets and use black RTV and you'll never ever have a intake leak in those locations.
Currently running Fel-Pro 1205 since these heads needed a little larger intake port opening. I have always put a light coat of black RTV around the water passages on the head, installed the gaskets onto the head, put a little more black RTV over top of the intake gasket where the water hole are-making a gasket sandwich then applied a generious amount of black RTV on the front/back parts of the block. I've never had a leak to date weather it be water or vaccum.
ambainb
Apr 25, 2016 09:21 PM
