Throttle Shaft Re-Bushing kits?
I have a 650 Holley DP and the idle is a little eratic. Sometimes it idles at 800rpms, sometimes 600, sometimes 1,000. I've double checked almost everything else(timing, idle screw moving, idle mixture screws, etc.) and now I'm beginning to think that the throttle bushings are leaking a little vacuum every now and then cause there is a little slop in them(carb is 7+years old).
Has anyone changed out the bushings? Is it difficult or expensive to do? Does anyone know of any kit that does it? I remmember seeing one but for the life of me I can't find it now. Thanks for the help.
Nick
Nick
Car: '82 Camaro
Engine: 383
Transmission: TH-350
Look in a phone book for carburetor shops. When I needed it done for a Q-Jet I found a place that advertised that they do throttle shaft bushings. I found a kit, but it costs more than what it would be for shop to do it since you have to get a special tool for it. Check here . There is a post about someone here doing it without a kit (on a Q-Jet) but you need access to a drill press. Holley's I don't think are as prone to trouble with the throttle shafts, so make sure they are bad. Try to wiggle the primary throttle shaft (up, down, fore, aft). There should be very little movement, if any. Some Holley's use some teflon strips I think as "bushings". My Holley rebuild kit had some in it, maybe that is all you would have to do. Hopefully one of the knowledgeable Holley people will be able to give more info.
Car: 92 RS 25th Anniversary Edition
Engine: treefiddy
It's been a while since I disassembled a holley but I think they have the same bushings as a q-jet. Check my post
https://www.thirdgen.org/techbb2/sho...hreadid=206860
This has saved several carbs here...
Terrell351
Jun 13, 2021 01:13 PM
ambainb
Apr 25, 2016 09:21 PM
someone972
Aug 30, 2015 12:52 AM
