bogging @ speed....confused
Old Dec 21, 2004 | 04:49 PM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
The brand new 350 in my 85 TA runs great, except when I hit about 60mph and up under moderate thorttle to WOT, when it feels like I get either vapor lock in the fuel line or the ignition cuts off momentarily until I let off to mild throtte. It is not repeatable in the driveway, so I cant tell what's going on.
I am running the same computer Q-jet , intake, and ignition that came with the old LG4 305. The rest of the motor is a mild combination of a .420 lift cam, ported 416 casting heads, flattop pistons and headers.
I've been told that the Q-jet should easily be able to handle my setup. I recently had it rebuilt at a local carb shop, and the guy told me it was in horrible shape when I gave it to him. Up until now, I've been an injection guy, so the only thing I know about carbs is how to bolt them to the intake.
So should I get a carburator manual and try and fix the problem or just dump the whole thing and spring for a Holley and an RPM? Or am I looking in the wrong place all together? Since this only happens during or after the 3-4 shift, could I be looking at a transmission problem?
Any help would be greatly appreciated.
-Corrupted
Old Dec 22, 2004 | 08:57 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Most likely you've got a fuel delivery problem.
Try to get a fuel pressure gage on it so you can monitor it when these symptoms show up.
My bet is you're running out of fuel under those conditions.
Old Dec 22, 2004 | 04:53 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
hmmm, new fuel pump?
Old Dec 22, 2004 | 05:30 PM
Car: '85 TA
yeah, i have a new stock replacement fuel pump. the car is at the shop for the moment getting the A/C charged. I will check the pressure as soon as i get it back. any idea what the pressure is supposed to be?
Old Dec 22, 2004 | 05:55 PM
five7kid's Avatar
4 to 6 psi.
Old Jan 6, 2005 | 04:02 PM
Car: '85 TA
it turned out that the mixture solenoid was bad. i got that fixed and i know its working, cuz it makes an annoying clicking noise. also, the fuel pump makes 5 psi all the time
but at full throttle under load (uphill, or with three people in the car) the car stumbles and almost stalls until i let off the gas. the timing is dead on. is there something wrong with my carb, or the fuel just sloshing around?
pjsparts
Oct 29, 2025 06:39 PM
RedLeader289
May 28, 2019 01:47 PM
Infested
May 22, 2018 11:56 PM
Grant2k
Apr 4, 2016 08:21 AM
middian
Sep 5, 2015 01:42 AM
