Bogging
Old Dec 27, 2004 | 09:14 AM
steveiguess's Avatar
Car: 1986 Camaro
Engine: zz4 350 w/mods
Transmission: 700-R4 W/Shift kit
Bogging
I have a fairly new holley 750 w/ vac. sec. and elec choke. (not dbl pumper) on my 350. Its got the zz4 heads, headers, etc. the cam is a .494 lift cam on intake/exh. sides. When i am driving and i give it a little gas on the go it boggs, and when i am from a stop and launching it boggs. I have adjusted the timimg to compensate for this, along with the replacing the power valve and the accelerator pump. I was wondering if anyone knows how i can fix this, or if i should go and get a new carb. I have been looking at the new 670 street avenger. is it possible i am over carbing my motor?
Old Dec 28, 2004 | 01:37 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
It sounds like your accelerator pump isn't giving a big enough shot when you hit it. You replaced the accelerator pump, was it the same size, bigger or smaller? I think if you adjust for a bigger shot you'll be fine.
pjsparts
Oct 29, 2025 06:39 PM
RedLeader289
May 28, 2019 01:47 PM
Infested
May 22, 2018 11:56 PM
Grant2k
Apr 4, 2016 08:21 AM
middian
Sep 5, 2015 01:42 AM
