Idle question
Old Jan 1, 2005 | 11:00 PM
cyipher's Avatar
Car: 1984 Pontiac Trans Am
Engine: 305 SBC
Transmission: Automatic
Idle question
I just switched to 1.6 rockers, now im having a idle problem, the car dies when idleing, is this normal to have to readjust the idle after a rocker change or did i miss somthing? I havent started my car when cold so i dont know if this is a problem that pertains only to hot starts, but any feedback would be great. thanks
Old Jan 2, 2005 | 10:36 AM
cyipher's Avatar
Engine: 305 SBC
Ok, went over all vac. lines this morning, found nothing, also rechecked with carb ceaner, and still nothing. So i readjusted the idle slightly and now the car is running great, no stalling, and no problems with cold starts.
Old Jan 2, 2005 | 11:50 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Are you sure all the rockers are adjusted properly? I can't really see how changing the rockers would mess with the idle unless they weren't adjusted right and maybe not opening enough to let the engine breathe enough to run, but I doubt thats it.
Old Jan 2, 2005 | 11:57 AM
cyipher's Avatar
Engine: 305 SBC
well the 1.6 rockers open sooner as well as providing more lift, so the durration does change slightly.
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
