engine won't idle
Old Jan 15, 2005 | 12:40 AM
dukemushroom1's Avatar
Car: 1991 camaro rs
Engine: 383 stroker
Transmission: th350
engine won't idle
well, it was running fine one day then the next day, after it started getting cold, it didn't want to run. that's understandable. i waited a few weeks and tried again, after warming up, the engine and the temp. outside, it still won't keep idle in gear. it's a holley 4150.
Old Jan 15, 2005 | 12:56 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
did you try to adjust the idle mixture or idle speed screws? won't idle at all? what RPM does it drop the motor down to. 5 minutes screwing around with a vacuum guage and the screw settings might solve your problems. also, this carb have a choke on it as well?
Old Jan 16, 2005 | 09:03 PM
Car: 1991 camaro rs
Engine: 383 stroker
Transmission: th350
yes, it does have a choke on it but it's working fine...my bro came by and thinks it might be a distributor problem (it's happened to me before) because when he was working on it we got consistent backfiring and a rough idle. were going to swap in the dist. from his engine to see if it will run with that.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
backtothe80s
Sep 5, 2015 12:39 AM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
