vacuum secondary prob.
Old Feb 19, 2005 | 09:34 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
Axle/Gears: ford 9in 4:56 to 1
I am running a dual holley setup on my z and prob. is the vacuum secondaries dont operate together(not even). I have found secondary covers with hose nipples on them.Was told to put these on and connect together with a piece of hose and it will equalize them. Do these work? or a waste of $
Old Feb 20, 2005 | 08:42 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
anyone! any thoughts or suggestions?
Old Feb 20, 2005 | 09:52 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Connecting the vacuum secondary pots will balance the vacuum signal to both pots but will not solve a problem with one of the secondary diaphram's seal or the seal between the diaphram pot assembly and the carb body (small round cork gasket).
Check the secondary throttles for free movement also.
A over-thick carb base gasket can cause the throttle base plate to warp and bind the throttle shafts. So can corrosion.
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
sreZ28
Oct 22, 2015 08:21 AM
HoosierinWA
Oct 7, 2015 10:15 AM
dusterbd
Sep 29, 2015 08:40 AM
