do i need to run a choke
Old Feb 21, 2005 | 09:46 PM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
Being rather ignorant of carbs, i have a question about chokes. Do i actually need a choke on the carb? Im looking at buying a 650 dp off a gentleman but he doesnt run a choke. My car sees daily duty. somebody help me out. thanks
mitch
Old Feb 21, 2005 | 09:48 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You don't need a choke, but for a daily driver in cold weather you'll really, really want one.
Old Feb 21, 2005 | 09:50 PM
OutLaw305's Avatar
well i put the car up in the winter... can i get away without if for the summer and worry about it when fall approaches?
Old Feb 21, 2005 | 09:57 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
i have a freshly rebuilt holley 650 model 4165 list 6210 that has a manual choke ready to go. i can get pictures if you want.
Old Feb 21, 2005 | 09:59 PM
OutLaw305's Avatar
are you saying you are selling it? pics are always nice as is a lil more info about it
Old Feb 21, 2005 | 10:04 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You can probably get away without it in summer. You just have to feather the throttle to keep it running after a cold start without a choke.
Old Feb 21, 2005 | 10:23 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
if it's warm i don't see the need for a choke as much as around here in the midwest in winter. My camaro doesn't run a choke since it's a warm weather car and i'm used to having to wait a minute before driving off.
Old Feb 22, 2005 | 01:29 AM
MonteMan357's Avatar
Car: 1991 Z28
Engine: 357
Transmission: T-56 waiting to go in!
Axle/Gears: 3.73:1
and you can always get a choke kit for 20 bucks from summit if you really want one.
Old Feb 22, 2005 | 01:46 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A choke kit will convert a manual choke to electric, but it won't help if the choke plate has been removed or if the carb has no choke at all.
Old Feb 22, 2005 | 02:00 AM
Car: 1991 Z28
Engine: 357
Axle/Gears: 3.73:1
welp shows how much i know...im one of those guys who runs no choke and have no problems with it
Old Feb 22, 2005 | 08:06 AM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
If you just driving it in the summer, I'd say go for it. You may have to hold the pedal down a little bit during cold starts, but in the summer cars warm up pretty quick. If it gives you problems just get a manual choke for it for like $20 and that will help you with the cold starts.
Old Feb 22, 2005 | 08:16 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
yeah i am going to sell it. my 350 plans with a different motor has been cancelled because a friend bought my old block. i am looking at around 175 or so. i will be able to snap a few photos on thursday. my sister took my camera with them on vacation.
Old Feb 22, 2005 | 08:34 PM
OutLaw305's Avatar
im sorry, i just bought a carb from someone else. Thanks though
Old Feb 23, 2005 | 04:49 PM
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
Anyone who has removed a choke from a carb probably isn't the sort of person you want to buy a carb from let alone anything else. It shows a certain lack of brains to remove a choke plate, as it causes any engine in any climate trouble.
Yes I can live without it but it isn't good to miss it. If anyone knows where I can get a replacement choke plate for a holley 4160 carb then I will be the next person to buy one.....
Si.
Old Feb 23, 2005 | 05:02 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There's nothing wrong with removing the choke. It's a common modification to increase airflow through the primaries on racing carbs, or on cars that only see summer use. Holley and Demon have entire series of carbs that not only don't have chokes, but don't even have choke towers in the castings.
Old Feb 23, 2005 | 05:05 PM
iroc-si's Avatar
yes, get the right carb but don't screw up the wrong carb!
No choke has no place on anything but a top end dragster. And certainly not on a 650cfm or the like carb. If you need the extra airflow get a 700, 750 +++ carb, don't be stupid and remove the choke plate from a low spec carb!
Si.
Old Feb 23, 2005 | 05:54 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
mine has one... don't bother using it... car has fired right up on 3 pumps in 10* weather... yeah you have to sit there and either drive it, or give it some gas, but it runs fine...
Old Feb 23, 2005 | 06:42 PM
Chris5k's Avatar
Car: 85 Berlinetta F41
Engine: 355
Transmission: TH700
Axle/Gears: 3.73 posi
Iroc-si I have a holley 600 VS sitting in my shed collecting dust.. (4160) have a new one on my engine also, removed the choke.. I live in florida and even in the winter its not that cold.. even with choke I cant drive my car so I dont see the point... also it would stick and **** me off so i removed it. anyway I would sell you the choke plate for whatever it costs to ship it and like a dollar.. hell i'll send you the whole linkage and everything..
Old Mar 7, 2005 | 06:51 PM
drmarc's Avatar
Car: 85 Trans Am
Engine: 305 4bbl
I was having problems with my 305H and it turned out to be the choke seized in a full-choke position. It caused the engine to flood after 10 minutes of driving finally. So now, i cheaped out for the moment and just had the mechanic leave it open to a normal running position. And even these cold canadian winter mornings she'll still start, albeit with a good bit of cranking and pressing the pedal for 10 seconds every 10 seconds. I just have to make sure my batterys good and strong.
eightsixseven
Dec 16, 2024 01:50 PM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
86IROC112
Aug 17, 2015 02:00 PM
mustangman65_79
Aug 11, 2015 03:17 PM
