Vacuum Advance
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Vacuum Advance
Which one shoul di hook mine up to a constant vacuum or the one that kicks in at half throttle?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Ported - opens just after idle
Manifold - always open
Well now you went and did it, opened up the real can of worms.
You can do a search, I think Chickenman and F-body88 had a debate about it. but, to sum up:
Your choice. Try one, then try the other, go with the one that suits you best based on your driving habits etc.
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
