4309 regulator a poor shortcut?
Old Apr 23, 2005 | 06:28 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
What's everyone's views on using the Mallory 4309 regulator with a TPI pump to drop the pressure? I'm trying to figure out if I'm going this route or if I'm going to use an external inline pump.
Old Apr 25, 2005 | 01:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Since nobody else has responded, I'll venture in and say that the approach is fine as long as the pump lasts (and it should last at least as long as you could expect one to last in a TPI system).
If you go with an external in-line pump, remove the in-tank pump.
Old May 1, 2005 | 05:13 PM
AutoRoc's Avatar
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
That Mallory regulator works great. Worked for me personally and for a few other local guys.
I foolishly sold mine thinking I didn't need it but I realized I need 2 of them now. I did some research and am using 2 Aeromotive Universal Carb-Bypass regulators now. They come with a spring for carb pressure and also an EFI pressure spring. Looks like a solid piece of hardware too!
Goodluck!
Old May 1, 2005 | 05:55 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I went with an external inline pump and it wouldn't pull through the tpi pump so I had to remove it. Some have said they can pull through it though.
Old May 3, 2005 | 12:43 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Goodluck!
Why do u need 2 regulators? are u running one pump motor one nitrous?
Old May 3, 2005 | 12:45 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
When i converted mine to carb i pulled the tank took the pump out and ran a hose down in place of pump and im using a holley blue pump. Man is it a paiin in the *** to drop the tank its a all day ordeal when stuff wont work with you.
Old May 3, 2005 | 07:55 AM
Engine: LB9/383
Well I've just decided that the stock TPI pump isn't going to support the motor anyhow so I'm going to have to drop the tank no matter what. soooooooo I'll be making a pickup and running an external aeromotive a-1000 pump and their bypass regulator. Thx.
Mark_ZZ3
May 24, 2018 01:02 PM
gixxer92
May 18, 2017 11:20 AM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
Dragonsys
Sep 25, 2015 03:51 PM
