87 berlinetta fuel filter location
Car: 1987 Camaro Z-28
Engine: 305 cu. in.
Transmission: Automatic
I need help. i have a 1987 berlinetta camaro and i do not know where the fuel filter is located at. I check in the driver side rear tire. and i counld not find it, can some one help me out
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
EDIT: This is on the carb forum, this should be a carbed car then...
If carbed it'll be on the carb. Front of it. Stock carb?
Try putting some info in your personal info there so we know what you have, that'll help us skip the step of asking you each time you ask a question.
Oh, and Welcome to the boards!
1992 Trans Am
May 10, 2023 07:19 PM
92camaroJoe
Aug 13, 2015 06:07 AM
